Lowest RMS rating a Death Penalty can handle
How are you running three amps all on the same sub? How do plan to wire that and are the amps capable of doing it? I am not tracking the Clarions are strappable.
Am I missing something in the reading?
Not sure why you don't just go with one sub amp that gives you the power you need.
this whole myth came about from people using tiny amps on big power subs, and thinking, "well if i turn the amp all the way up it'll be fine" most amps start puting out distortion around 75% up on the gain depending on deck setting and other crossovers that might be being used, the distortion will cause excess heat and can ruin the sub.
but under-powering a sub with CLEAN power is not possibly only with distorted power.
/ thread.
You can run it off 0 watts when it's sitting in your room not connected to anything like this sub is sitting in mine, and will be for the next few months.....
Cudda_Kine
Cudda_Kine
Hawaii
helotaxi
