VWBobby
PG and SS nuthugger
Touché!The sensitivity spec is worthless on a sub since it is derived at 1kHz.
edit: Actually.....! Even if the spec is derived at 1Khz, it could be argued that a sub with better sensitivity would respond better than one with less sensitivity for the given watt.
It has been proven that a sub with a heavy coil will put out less db's than a sub that has a lighter coil, fed the same power.
Mass x Acceleration. If it takes less Force (power) to make the sub respond, chances are it will be louder and have less distortion below its peak than a sub with a heavier coil or suspension. //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
Thoughts?
