Low power sub selection
JimJ
Tangled Up in Blue
Still trying to decide what sub to use for my home setup, have 16" x 25" x 26" of space to play with, and 250W at 4 ohms.
Thinking along the lines of Adire Shiva, Type-R, etc, etc...
any others?
help me narrow this down //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Shiva sounds good, tempest sounds even better, although i'm not sure of box sizes. Maybe also dual koda8's. THe shiva would do a killer job with that power though, so I think regardless you'd be satisfied.
dual koda 8's would be tough to swing with the impedance config's...at least in single fours.
shiva would fit perfectly, impedances would match too...just not sure what box size to use.
i would say the tempest.....
or if money isn't a big issue..check into http://www.soundsplinter.com mke's line of subs can be used for home audio as well.....and if u get an rl-p, u get either d2 or d4..so impedence shouldn't be a problem..email mike@soundsplinter.com and he'll be able to answer those questions better..
also, the tulmult is supposed to be the best..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Two single 4 ohm coils would work perfect for home audio actually....most reveivers rate their power at 8 ohms because it allows for less signal distortion.
but the parts express plate amp i'll be using does max RMS at four ohms...
and to finally say this...I don't have room for a Tempest! I'd get one if I could, but I simply don't have the room! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and i can't use a tumult b/c:
it's a 15, same reason as the tempest
takes too much power
way too loud for my needs
way too expensive
and i'm a colllege student, so yes, money is a huge issue.
soundsplinter...lol...
check em out jack...hehe
or the shiva..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
check this link...
http://forums.caraudio.com/vb/showthread.php?t=69408
scroll down to u find his post about his tc sounds tc2+ sub...$130 plus shipping.....
that is the one u want (soundsplinter's rl-i series is based on the tc2+, tcsounds ia ss's OEM)
that's a sweet as price for a killer sub!!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
My brother just picked up the Shiva in a ported box. It runs of a 200 Watt Profile amp. It's loud enough to make your ears hurt. I don't see how people run so much power with multiple subs for non competition use.
hehe...well, the tempest might be in the works //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif have to work out the enclosure design first though.
a 15 in a dorm room, ****, who am i kidding...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif i'm crazy, aren't i...
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
589
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
739
JimJ
Tangled Up in Blue
JimJ
Hillsborough, NC
OLD_SCHOOL
