DD9917b on a 4kw, too much?
  • 4
DiB
Meber
211
San Diego
Ok, do you think a 4kw is too much power to have on a single DD9917b for daily driving? Also, since the 4kw is really two 9.0's, can I just bridge the two 9.0's into 2ohm each then run a wire to each coil or would that be bad. I always hear mixed results on this.
Well, that sub is a beast. It can take just about anything for competitions...but daily...some subs are more temperamental (sp?). Anyways, i'm not all familir with the entire design of the 9917...so, does it have a vented pole piece? JW, b/c when i was looking into an RE MT (competition sub mainly) and was going to run 3000 rms to it daily...i was told that it could get warm b/c of the lack of a pole vent...but it would be fine. As for the 4kw...i've heard u can run it like two individual amplifiers...but i'd ask zapco or someone that hhas first hand experience b4 u try it. peace
NG
i just called dd up and asked about their thermal handling. the 3515 can handle 500deg, and they said that its really hard to get that hot with clean power. call them up and see what they say. i think it may be a little too much.
Yes you can run it like 2 individual amplifiers but in doing so and putting each amp on each coil I wonder if it's good for the sub(will the signals match?) especially at the power levels it can produce. I'll call DD up and ask em. I've seen my 4kw hit 8kw while listening to Outkast and hold so as far as having enough power to hurt it, I think I'm there, lol.
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
DiB
Meber
DiB
San Diego
Randy Savage
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
