So I recently blew a few skar vvx10v2 and I have 3 triple stacks .784 2.5"VC motors and decided screw it I'm just going to attempt to build 3 woofers on these motors looking at the baskets available on the lord of bass and psi. found some coils that will work on these motors nicely..... the final decision is should I just make them into 12" or 10" with a new basket or should I just reuse the baskets and just do a recone with raw mats...What do you guys think?
Magnet specs I measured
Top Plate Thickness: .4 (10.16mm)
Top Plate Inner Diameter: 2.8 (71.3mm)
Pole Outer Diameter: 2.513 (63.8mm)
Ferrite Outer Diameter: 6.375” (162mm)
Ferrite Height: .784” (19.90mm)
Ferrite Count: triple stack
Gap depth: 2.880" (73.14mm)
Bolt Pattern: 5” (127mm) x 6
and these are the coils I'm looking at using (just wish the winding width was longer)
https://thelordofbass.com/product/2-5-dual-2-ohm-round-aluminum-voice-coil/
