Looking at a first-time "serious" build.
Garrett Morgan
CarAudio.com Newbie
Howdy y'all, let me apologize in advance for what seems like is going to be a lot of text.
I'm pretty new to the whole audio system thing. I've done the basics before, a new head unit, some (decent) speakers, but never a comprehensive system working in tweeters, amps, and sub(s).
I've been studying up on as much of the basics - everything I think I need to know to at least get started in the right direction. I've put together a little spec sheet of a build plan, though I'll likely be buying piece by piece and doing small batches of installs at a time. I'd really appreciate any time you guys can take to look over this build. Yes, it is a pretty cheap build, but I think it gives me a good amount of room to upgrade things as I go, and gives me a good platform to start with.
Just a couple of other things;
- It's going into a 2009 Honda CRV
- I'm aiming for a decently loud system (loud enough to feel kinda surrounded by the sound), but really looking for decent balance of sound.
- I'd really like to run a single power and ground from the battery, and included what I think I'd like to use to split that properly.
Below I've just listed the build sheet, with links that (hopefully work).
For my highs/mids, I've gone with:
  • Kicker 46CXA360.4T
  • 4 channels, 65w RMS at 4 ohms, and says it has a "best frequency range" of 10-20k Hz.
  • Calls for a 40 amp fuse.
This is powering two sets of speakers .
  • Polk DB6502 component + tweeter set
  • 6.5" speakers, fits my front doors. tweeters fit in my existing dash locations.
  • 100w RMS and 300w peak, 4 ohms, says that the kit is good for 35-23k Hz.
  • Comes with crossovers that seem to allow you to choose between 0, +3 db, or +6 db using jumpers.
  • Polk DB652
  • Two component speakers, fit the rear doors.
  • 100w RMS and 300w peak, 4 ohms, says that the "Frequency Response" is 40-22k Hz.
For my bass needs, I've gone with:
  • Rockford Fosgate R2-500X1
  • Mono channel, 500w RMS at 2 ohms, and says it's "best frequency response" is 20-250 Hz.
  • Calls for an 80 amp fuse.
Subwoofer:
  • Rockford Fosgate P3D4-10
  • 10", 4 ohm DVC, wired in paralles for 2 ohm impedance
  • 500w RMS, 100w peak, "Frequency Response" 28-250 Hz.
I intend to power both amps using:
1 1/0-gauge power wire, splitting to 2 8-gauge power wires
2 8-gauge ground wires from the amps, combining to 1 1/0-gauge ground wire
And using this 1/0- to 4-gauge wire dual fuse block, in conjunction with two 125 amp fuses:
EFX DFB0 Delta Dual Fuse Block
  1. Not right now
Are you dead set on this or you want suggestions?
Definitely open to suggestions (read as please help). What I've got there is really the roughest idea, simply what numbers matched up.
The only reason I went with the Polk speakers is because I have a set that have been with me and/or my brother since ~2009 and they're still kicking, and I've read that the rockford fosgates are generally decent.
It prices out to a little under $1,700, and I think I'm still trying to stay around that in price at this point.
I think that's a better sub than the p3 and it's on clearance since they released the ultimate II
That's a solid sub amp
That's about $200 cheaper than the rf stuff you posted and imo will perform better.
I'd use the savings to deaden your doors some so the 6.5's will sound better
So, I'm still relatively new to this, would there not be an issue with the amp outputting 1000w at 1 ohm and 700w at 2 ohms since the sub is only rated for 500w and could be wired to be either 1 ohm or 2 ohms?
Do you have any other recommendations if I'm not able to swing it on clearance (or before they run out of stock)?
Also, do you have any recommendations for deadening materials? I've seen some people recommend the NVX baffles, how does that play into the deadening/setup?
Sorry for all of the questions.
Those are good brands, but here are a few suggestions. The Precision Amps are known as being really reliable and are made in Korea, where the quality is much better than China. The subs you picked are 500 watts each. Therefore, you will need a 1000 watt amp, or two of those 500 watt amps.
Polk Audio is decent. They are not nearly as good as their home stuff. However, get the speakers that give you the sound you like.
For a sub, this single 12" will give you a lot of bass. It moves a lot of air and sounds really good.
Thanks for the suggestions.
The amps are listed as "vertical", does that effect anything in any meaningful way as far as mounting and such goes?
Also, do you think that the 12" sub is the way to go for that kind of "punchy" bass feel? I've got another car that I'd added my Polk 6x9s to the rear deck to function as faux subs, and there's this feeling of like the individual hits on the bass drums (rock, metal), or on like the accented notes on the bass lines (rap, dubstep), in my chest, that I've become addicted to. I'm sorry to ramble on about it, but I'm not sure how to achieve that with a higher quality system.
If you will be running your amps flat, check out these.
For punchy bass, it depend on how big of a box your are willing to go with. That single 12 will be punchy as heck. Especially in a 1.5 cubic ft box.
It'll be fine...just set the gain lower. The upside is you won't be pushing the amp to the max
More displacement is always "better" so the more air your subs move the louder they'll be. Truthfully though better is a pretty individual taste thing. A good 10 will be more than enough for some and not even in the ballpark for others 😂
So it really comes down do you want just good sounding music or some added giggle factor for your stereo
The 4-channel is for the mids and highs. The mono block is for the subs. Were you looking to run a separate amp to the tweeters?
Ah, I just don't know how to read lol. And no, I was just planning on tying them into the front speakers with crossovers, though in the future I might try to add some smaller coaxial speakers in the dash for mids.
Would the 60w rms (x4 @4Ω) be enough to reasonably drive the 100w speakers? I'm not entirely sure exactly how that works, aside from trying to avoid too powerful an amp. Wouldn't the amp be in a high state of use to power those? I'm really not trying to be critical, I'm just trying to understand as a lot of this is still very new to me.
I would recommend the A700.4D over the A400.4D, but I was going off of the wattage of the Kicker amp.
Again, there are cheaper and more powerful amps out there. The only problem is, reliability is not the same. Some will get 5 years from those amps, while others will get much less. The Precision Power amps are not as good as they were, back in the day, but they have still proven themselves as being very reliable.
I have the Precision Power (PPI) PC1000.5D amp in my F150. I have had it for almost 2 years with no issues. I purchased the A1800.1D and A700.4D for my kid's Ranger. It will be driving an NVX sub and NVX speakers. I am that guy that has to buy quality because my wife will only let me buy it once. LOL...
Thanks again, I really wasn't expecting to get a lot of help, I checked the Car A/V reddit first and got nothing back from them.
Do you have a rec. over the polk sets? I'd originally been thinking of Kicker, but a lot of my purchases are going off of user feedback and reputation, since I don't have a great way of going to hear how the different sets perform.
Garrett Morgan
CarAudio.com Newbie
Garrett Morgan
United States
Garrett Morgan
