Looking for some help for a amp
Killerk
ok im going to get
SWR-12D4 Type-R 2 of them
Head unit Kenwood KDC-355U
was going to get Planet Audio AC5000.1D
but i dont know if it will push it good also looking for something in that price range 145$ and i was going to get XS Power D925 to run them but if i dont need it that be great im running it in a 97 blazer
The planet audio is not a great amp by any means. For your budget on the amp I would look used on here. I would wait for something to pop up. Otherwise somebody here may be able to help guide you to an extreme budget amp like an audiopipe, shark, ppi etc. I just don't have experience with those. How much are you paying for the type r's? Might be something better out there also
only paying 150 each for the Alpine SWR-12D4 Type-R
I will be selling most of my system, since you are local you can take a listen to demo it once your ready, my other stuff is still on its way but in the next couple weeks I will be swapping stuff out, and I can make you a good deal .
I will 2nd the opinion on Planet Audio products. Their older amplifiers were pretty dang good, but like with most brands nowadays, the quality has diminished significantly. Any amp over 1000 watts that can be purchased for under $200 brand new is a red flag.
what gauge wire should i be using with this setup i was thinking 0 but idk now lol i will be getting the Precision Power PPI BA5000.1D and dont know if it can take 0 gauge wire for the power wire
[Killerk;8641256]It is not 4 gauge cause i got a 0 t0 4 gauge reducer and it did not work for it
Interesting cause I have the same amp and it takes 4 gauge no prob. So is the reducer too big? You can file it down to fit.
Hey, I have golf 2019. I have audison voce and want another speakers in front, and the Audison move to the back I have thought about those- Focal...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
I combine the fuse ratings of both amps and use that at the battery with the appropriate size wire and if an amp doesn have onboard fuses I will...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
Killerk
Killerk
Las Vegas,NV
Killerk
    May 18, 2024
    May 16, 2024
