da box king
a true 4000 @12.4 volts...will do close to 5k @ 14.4it puts out a true 4k watts doesnt it?
Right around 22kw. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifIt's "weak". And I'm supporting 20kw. You?
Thank you for adding a subsonic, thats the reason i did not like my first Stetsom. Still was good power though, just wasnt able to overpower my speaker how i wanted to without a subsonic. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif Great power though, in a tiny tiny case. My 3000 watt stetsom was the same size (taller/thicker case though) as a 600 watt profile amp.these are the specs on the 2 ohm version
V 5K2D
FEATURES 5K2 D – 2 OHMS
Number of Channels: 1
WRMS Power (1 ohm) to 13.8 V: -
WRMS Power (2 ohms) to 13.8 V: 6.850 Watts
WRMS power (4 ohms) to 13.8 V: 4.290 Watts
WRMS Power (1 ohm) to 12.6 V: -
WRMS Power (2 ohms) to 12.6 V: 5.700 Watts
WRMS power (4 ohms) to 12.6 V: 2.540 Watts
Supply voltage: 9 to 15V
Frequency response: 20Hz a 8KHz
Low Pass Crossover: 50Hz a 8KHz
Signal Noise: > 90 dB
Total Harmonic Distortion:
Input Sensitivity: 0.2 V
Input Impedance: 20K ohms 20K ohms
Low Output Impedance: 2 OHM
Consumption with dash: 3,5 a 260A
Consumption with BASS Signal: 3,5 a 520A
Subsonic filter: 20 to 80Hz 20 to 80Hz
Dimensões (A x L x C) mm: 70 x 280 x 456
Weight Kg: 6,6 Kg
than maybe you should get your priorities straight how about that... not to mention for what little bit you've shown you know about car audio... you have NO BUSINESS around 4k watts...i realize that but its hard to spend 3000 on a system when you only make 400 a month currently
Apparently he has 4 gauge and a cap.I'm sure it's been asked earlier, but do u have any sort of electrical upgrades to handle upwards of 4kw daily??
