looking for a 4000 watt amp
I think this amp at 650usd is what you want.
Three good batteries and a 200 or better alt and you are set.
V 5K2D
FEATURES 5K2 D – 1 OHMS
Number of Channels: 1
WRMS Power (1 ohm) to 13.8 V: 6.560 Watts
WRMS Power (2 ohms) to 13.8 V: 4.140 Watts
WRMS power (4 ohms) to 13.8 V: 2.330 Watts
WRMS Power (1 ohm) to 12.6 V: 5.475 Watts
WRMS Power (2 ohms) to 12.6 V: 3.600 Watts
WRMS power (4 ohms) to 12.6 V: 1.985 Watts
Supply voltage: 9 a 16V
Frequency response: 20Hz a 8KHz
Low Pass Crossover: 50Hz a 8KHz
Signal Noise: > 90 dB
Total Harmonic Distortion:
Input Sensitivity: 0.2 V
Input Impedance: 20K ohms 20K ohms
Low Output Impedance: 1 OHM
Consumption with dash: 3,5 a 260A
Consumption with BASS Signal: 3,5 a 520A
Subsonic filter: 20 to 80Hz 20 to 80Hz
Dimensões (A x L x C) mm: 70 x 280 x 456
Weight Kg: 6,6 Kg
these are the specs on the 2 ohm version
V 5K2D
FEATURES 5K2 D – 2 OHMS
WRMS Power (1 ohm) to 13.8 V: -
WRMS Power (2 ohms) to 13.8 V: 6.850 Watts
WRMS power (4 ohms) to 13.8 V: 4.290 Watts
WRMS Power (1 ohm) to 12.6 V: -
WRMS Power (2 ohms) to 12.6 V: 5.700 Watts
WRMS power (4 ohms) to 12.6 V: 2.540 Watts
Supply voltage: 9 to 15V
Low Output Impedance: 2 OHM
Weight Kg: 6,6 Kg
V 5K2D
Weight Kg: 6,6 Kg
Thank you for adding a subsonic, thats the reason i did not like my first Stetsom. Still was good power though, just wasnt able to overpower my speaker how i wanted to without a subsonic. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif Great power though, in a tiny tiny case. My 3000 watt stetsom was the same size (taller/thicker case though) as a 600 watt profile amp.
i realize that but its hard to spend 3000 on a system when you only make 400 a month currently
than maybe you should get your priorities straight how about that... not to mention for what little bit you've shown you know about car audio... you have NO BUSINESS around 4k watts...
Well if I knew everything I wouldn't be asking for help on a forum now would I? I'm here to find a good amp that will pound my subs it doesn't really matter to me how much I make or how little I know and I don't believe I am as stupid as you think your probly what 35 40 ish? U have been doing this stuff a long time I'm only 18 I'm a beginer I'm obviously not going to be able to write a book on this
Find a used Sundown 3000D and run it daily @ .5ohm... Should do like 3500-4k depending on ur voltage.
I'm sure it's been asked earlier, but do u have any sort of electrical upgrades to handle upwards of 4kw daily??
Apparently he has 4 gauge and a cap.
Jesus christ. You even TRY running an amp on that, that puts out 4k watts, and you'll fry it so fast.
You need a new alternator, and at least 3 batteries. Good ones. Way more than 4 gauge wires, too. Even 0 gauge, you'd want two runs at least. You're looking at $800 in electrical upgrades likely.
shayne1134
shayne1134
Port Perry, Ontario
shayne1134
