system is as listed in the sig, minus the ax400's I was running for the fronts. One ran the tweets and midrange, the other bridged 4ohm per side to the Illusion mids. My DLS IR3's only go down so low. on the 12db bandpass they're set around 600hz ish to keep the low end of that midrange from distorting. The illusions can play up to that point and sound pretty **** good, but i also have them crossed at 125hz on the hpf. they'll still play down to 80hz pretty well at full volume and sound great, just not crazy midbass on the lower end.I posted a story on DIYMA about those old PPIs. You're not Mexican are you (search for that post...it's a crazy story)What's your system as-is and what are your goals?
At first I tuned the amp to do about 100wrm per side to the illusions in thier pods...but i guess being int he pods they need more powe to shine. MUCH to my suprise with the ax400 workin full tilt the illusions really shined. I was impressed by how not only the output, but the coil not getting too hot.Im also curious why a 1ohm impedance is necessary for a front stage driver, especially midbass. At some point you simply should go to an array of speakers, as it provides some benefits over trying to pump a lot of wattage through a single driver.
i emailed the cdt person, there wa a typo and it's only a single or dual 4ohm driver....no dual 2ohm.you run midbass 80Hz-500Hz?
i run midbass 50Hz - 160Hz, and i use a shallow slope for the HPF to get as much low end information up front to keep bass in my soundstage. works great. requires a helluva good install though.
many subwoofers have too much inductance to be much good over 200Hz. It's a case-by-case basis.
that CDT woofer seems like it may work for you (provided i has the freq. response you want).
Anyways, an accumatch will smoke those. I would not recommend Accumatches on regulated amps and even some unregulated. An old Fosgate or HCCA? Different story...
Anyways, here's the link for the Orion mids; Orion HCCA6 woofers Brand New!!! Warranty ads a/d/s/ | eBay
I have a/d/s mids from the same seller. Those are 2ohm woofers and are pretty much the same thing as the a/d/s woofer except the impedance. I'll vouch for these having more midbass than Focals, Dyns, and pretty much anything short of a dedicated subwoofer. I have 5.25" a/d/s mids that out performed Focal K2P's back in the day - I a-b tested them in my car and on a soundboard...no comparison. Those mids are ugly, but for $125 they're pretty killer.
As far as rebuilding a 6" mid...I'm sure it's possible but I wouldn't bother. Why do you need that low of an impedance? Were you thinking of running a bunch in series b/c if you were, 16ohm raw drivers have become more popular as vintage tube enthusiasts really like them.
ehhh..... on the fence about it. im pretty sure 8's wont go above 200-250hz without sounding like hell.....unless there's a miracle 8in out there that'll play high enough, i might be stuck with 2ohm 6.5's.....so your going to get some 8s?
no space for that....not right now at least //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifmy suggestion would be multiple 4ohm svc midbass drivers, that way they'll handle more power and get to a 1ohm load.
adequate space for multiple midbass drivers is difficult in general and usually they are implemented poorly. in addition, you have to be careful with their frequency response so you don't encounter comb filtering, and the locations for multiples result in drivers closer to the passengers.no space for that....not right now at least //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
