questions about strapping amps
has to go to both amps .the way the master salve works is that you only use the m,aster amp for the settings the slave setting dont work when this is done,but you still need all the wires for power ground and remote
okay I got power,ground, and the remote part, now how about the rca's how does that work. I have a clarion eq, on the deck rca in the sub to the mainout on eq then sub out to my one brz2400, now where do I put the other rca cable? or I dont need 2 when im strapping and I can run an rca from other jacks to the other amp?
both rca jacks from the eq to the l and r inputs then on the other side of the amp see the 2 single rca jacks one in one out and the switch master is out slave is in then your done
playyamxz550
playyamxz550
Memphis
playyamxz550
