Little help on wiring up second battery.... pics :)
hoxie08
i <3 drugs
Need help with wiring up 2nd battery and all... should I do it like this
or just ground everything to chassis where it is.... like this
or am i just completely wrong? lol
either would work... the best would prolly be a combination... both batts share a ground wire and each one also has its own chasis ground
and you need to put a fuse in between the batts on the positive run
yeah. i just found out someone said its best to fuse 12" from each batt... so that'd be 2 on just the + line between batteries... and yeah, i think i'll ground both batteries to the chassis, does make sense to have as many easy connections as possible..
is it absolutely necessary to use an isolator though?
also..... i only have 2 guage wire, but its really big and thats what ALL of this will be done with (bro bought me 40 feet for christmas).... what size fuses... 200 amp... 250?
hoxie08
i <3 drugs
hoxie08
Nashville, TN
DidUHearThat?
