Ripkon CarAudio.com Regular 185 46 Virginia Apr 22, 2019 #1 I just hooked up my system and my hu only has 2v RCA's. I'm running 2 sundown 12"s @1ohm on 1250w amp. I'm looking for a good budget line driver or would a line output converter be better? Click to read more...
n2audio 5,000+ posts OPTIDRIVEN 5,690 86 Lawrence, KS Apr 22, 2019 #2 You want a line driver. An LOC is to go from speaker level outputs to RCA's. That's not what you are dealing with. 2v is rarely, if ever the source of a problem. What exactly are you trying to fix?
OP Ripkon CarAudio.com Regular 185 46 Virginia Apr 22, 2019 Thread Starter #3 n2audio said: You want a line driver. An LOC is to go from speaker level outputs to RCA's. That's not what you are dealing with. 2v is rarely, if ever the source of a problem. What exactly are you trying to fix? Click to expand... Looking for a stronger/better signal.
Jeffdachef 5,000+ posts Gunz That Turn on Nunz 18,527 993 South Coast Metro, CA Apr 22, 2019 #4 a comprehensive solution would be a dayton dsp that gives you all the tuning functions you ever need. A cheaper solution would be one of this. Gives you 3 pairs of 7 volt pre-outs. https://www.sonicelectronix.com/item_46587_NVX-XEQ7-Graphic-Equalizer-Equivalent-to-Clarion-EQS755.html
OP Ripkon CarAudio.com Regular 185 46 Virginia Apr 22, 2019 Thread Starter #5 Jeffdachef said: a comprehensive solution would be a dayton dsp that gives you all the tuning functions you ever need. A cheaper solution would be one of this. Gives you 3 pairs of 7 volt pre-outs. https://www.sonicelectronix.com/item_46587_NVX-XEQ7-Graphic-Equalizer-Equivalent-to-Clarion-EQS755.html Click to expand... Awesome. Thank you for your help
