Lifting my jeep
  • 5
I'm somewhat confused by your description but thats not a shackle lift.
You kind of contradicted yourself there because the block will either go between the spring and the spring perch on the axle OR between the body and the frame. Not between the spring and the frame.
A block lift isn't hard to do at all, just find some 2" aluminum/steel blocks, cut them to roughly the same length/width of your spring perch and drill a hole for the end of the centering bolt on the leaf spring. Toss them in between the leaf spring and perch and you're done.
A body lift is when you have pucks or some kind of block between the frame and body. You have to lift the body off the frame a little, remove the stock body mounts or add to them with larger ones.
Now, a shackle lift is replacing your stock shackles that connect the leaf springs to the frame with longer, aftermarket ones. Not very hard either but sometimes it can be difficult if the bolts are siezed.
I'm somewhat confused by your description but thats not a shackle lift.You kind of contradicted yourself there because the block will either go between the spring and the spring perch on the axle OR between the body and the frame.
ya it goes between the lift spring and where the lift springs connect to the frame. btw, i have nowhere to build that stuff. i need a kit
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
676
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
989
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
Buck
little alien on campus
Buck
Inside of a pyramid
DB_DRAG_SPL
Decebal
    Jun 10, 2024
