LED Brightness
chetomatic
So I've hooked up 4 LED strips to my amp and a switch, like this:
---LED-----LED------TOGGLE SWITCH----LED-------LED---------
|____(+)Speaker Terminal on Amp (-)Sp. Terminal on Amp___|
(That's all 4 LEDs in series drawing power from the amp, with a switch in the middle.)
So all 4 are getting power from the amp, so that they flash to the subs' bass.
I've seen other posts that ask how to decrease the brightness, I'm wondering if there's any way to boost the brightness without increasing the amp output and thus making the subs louder. Perhaps some electrical device in between the wiring somewhere to amplify the power? My knowledge of wiring and car audio is better than some but is mostly on a common sense basis.
Thanks in advance.
your only way of making it brighter is if you somehow make the LEDs more sensitive to voltage. you could in theory raise the AC voltage of the speaker wire before the LED's, then bring it back down for your subs, but this would probably cause some sort of distortion/clipping
@double deez, thanks
@bubbagumper6, considering i know how to figure things out on my own with a little help, perhaps you could be a little less vague and tell me how to fix my problem?
chetomatic
chetomatic
Boston, MA
chetomatic
BP1Fanatic
BP1Fanatic
