L7 in a truck
  • 5
4th order blowthru or just perch something on the backseat like most...:rolleyes:
L7-12's like airspace.
5ft3 net is a good volume to start...
Jamming 2 L7-12's underseat is a project that probably won't turn out well.
Are you hell-bent on L7's? I'd equate them to Kaepernick: they're decent, but they don't live up to the hype, and they can't take any abuse.
I've own an 8, a 12, and a 15 L7. I liked the 12, but none of them were very impressive compared to the current market selection.
I agree a buddy of mine got 2 DC 15’s on a 8K for about 1500 and his is 100 times louder than mineI understand he’s got a lot more power and money wrapped up and alternator batteries and wire but for subs and amp comparison his is way better
Another downside is you can't use many other subs in the same box.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
267
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Jamesrich88
Jamesrich88
Terre haute
Buck
