KnuKonceptz claimed ampacity
In other words, 0.157226584 degrees C/second, or 0.2830079 degrees F/second. Five seconds, and it's slightly more than a degree hotter. :\ I don't know if I would run it for too long. Let's run this for five minutes, assuming that none of the energy is lost/absorbed by the environment. 0.2830079(60*5)=84.90237 degrees F. I am not about to go into the math for dissipation of this heat into the surrounding air/insulation. After consideration, I would say the wire has a temperature rise of about 50-60 degrees F after five minutes.
But as the wire heats up, the resistance changes right? (or did your equations account for that because I didn't really read your whole post).
Also what type of eng are you? I'm (EE) industrial controls.
I would recommend people to go back to page 4 and read post #60. :\ Then comment on that.
Read that and commented as I recall. Heat generation, insulation breakdown. I squared R basically. Does that change the fact the length of the conductor has absolutely no effect? People here seem to think a short wire can carry more current than a longer wire (of the same size). This myth needs to be debunked.
It changes roughly, but not enough to change the numbers to matter.
I'm not an engineer yet. :p I don't know the fields, but I'm on my way to being one. Some sort of electrical engineer. Thinking about RF of analog/digital circuit fields.
Go ahead and debunk it with your 20000 feet of 1/0 and 265 amps. You'll see at that point that the length does matter.
Not that it matters too much, but I'm also currently seeking a degree in electrical engineering. I'm in the Electrical and Computer Engineering Tech. program at Purdue. Two years down and two to go.
:facepalm: It's kind of hard to grip.
A short wire can carry a LARGE amount of current, but as long as it doesn't heat enough to cause a thermal runaway issue. This short wire can be using for a short period of time with a high current.
For example, I have made a pulse discharge system capable of 100kA pulses, but I only use 300kcmil in a 1' run for the interconnects. There is not enough heat generated in this 100kA 1mS(I think) pulse to break the connection or to get worried about extraneous heating.
I've had an argument with TnT_Sounds about an 8" piece of 1/0 being able to stand 600A(I think it was) and not flashing the insulation off. I will go find it if someone wants. I used the specific heat explanation as well.
I give up...
Cool. The 3rd year is usually the toughest. Good luck.
I don't think there's anything anyone can say. He needs to actually test it to see. I guess he's a "hands on learner." He needs to get that 20000 feet of 1/0 and put 265 amps through it and watch what's going to happen.
He's going to need a higher voltage than 12.8, as we've already discovered above. If he shorts a battery with that 20kft of wire, he will only draw some 83.3W from the batt. :p Nothing. Nor will there be a lot of heating.
McIntosh
McIntosh
Joliet, IL
McIntosh
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
