just need a little help choosing an amp for midrange
ferretslim
i have 2 cadence 8" 4ohm cvl84mbx in the rear says 250w rms
2 cadence 6.5" 4ohm cvl64mbx in the front doors says 250w rms
right now i am using a passive crossover from a component set with my head unite set to 80hz
using a JL G4500 sounds pretty good but mids dong go very loud
i am just wonder if these 2 options will work or witch is best
option 1.
i think i want to try and go active with an amp that has a crossover built into it.
i has looking at Hifonics MT Olympus Boltar 2 channel and run 1 rear and one front left side in parralel 1 channel and othere side on the 2nd channel think i would get alot of power to them this way i think it would be a 2ohm load on the amp and amp is supposed to do 500w rms per channel
here is a pic of the crossover
Image Sheet
option 2
Hifonics MT Olympus Jupiter 4channel 125w per channel 4ohm
here is a pic of the crossover im just not sure never messed around with active crossover
Image Sheet
i dono if even either of these are a good option, i am on a bugget and trying to get some very loud mid range here. maybe someone can help point me in the right direction
thanks guys in advance
So I have ordered the 2 Channel hifonics Mt Olympus Bolton. Just need to figure out how to wire it up. Just run the 2x 8" mids run 350watts each at 4ohms or run 500 to 2 of them on each channel in parallel 2 ohm load on the amp
Man... confusion
Any input anyone?
Man... confusion
Any input anyone?
Cool thanks for your help man I am beyond excited to get this amp hooked up.
Is it hard to set the crossover? Might have to find some help here in town
ferretslim
ferretslim
Canada
ferretslim
michigan born
    May 14, 2026
michigan born
    May 14, 2026
