JL TW5 build log
Once again I cry horse shit, excuses, excuses
Show me the money.
Seriously though how is it coming togther?
heres a couple.
slow because of all the rain.
all thats left is the carpet and stuff from you
have you considered placing a port between the the 2 sealed chambers basically making on chamber for both drivers? You will more than likely pick up a db or 2. Just a thought
i considered ported. jl doesnt suggest ported but they said if i did they need about 1.5-2ft each
I must have stated my thoughts incorrectly, I mean keep it sealed just join the 2 boxes making one larger box, by simply making a connector (pvc or mdf) connector
oh ok.
i did think about leaving the dividers out of it to make a shared chamber.
if this isnt to my liking then ill try a shared chamber
it started out as seperated because i was planning on doing it a lot different when i changed my mind i just left it seperate chambers. no real reason why exactly. although it worked out for a place for the batteries
cool, I just thought I would bring it up.
I haven't checked out the specs on your subs, but they look like they use an extremely large dia. VC, I assume they do this to keep it thin also?
the coils on mine are 7 inches
they do that so the motor can slide up inside of it.
i would love to see one of them apart but im not using mine to do it.
here are the specs since they arent on JL's site
Fs 27.52hz
Qes 0.511
Qms 11.230
Qts 0.489
Vas 2.10ft3
1 way (xmax) 9.7mm
efficiency (1w/1m) 85.87
Sd 98.256 in2
bones22
bones22
in my house
snfsh79077
