JL Audio W6 wiring
  • 4
WasHere
I need recomendations for wiring 2 JL Audio 15W6 (6-ohm) speakers to a PPAI PC21400.2 Amp.
I tried to wire them down to 1.5 ohms but think I may have done something wrong. They seem to be out of phase with each other.
Amp specs are:
350w x 2 @ 4ohms
700w x 2 @ 2ohms
1400w x 1 @ 4ohms
Try hooking them up in stereo, 3 ohms per channel. Or get 1 more 15w6 and wire them at 4 ohms mono. Running that amp bridged @ 1.5 ohms will shorten it's life.
Originally posted by indosia Try hooking them up in stereo, 3 ohms per channel. Or get 1 more 15w6 and wire them at 4 ohms mono. Running that amp bridged @ 1.5 ohms will shorten it's life.
It shouldn't shorten the life if it is 1ohm stable and he is saying tho?
His amp is not high current, It will produce maximum power at 2 ohms stereo, 4 ohms bridged mono. Running it at 1.5 ohms mono will shorten it's life.
Originally posted by indosia His amp is not high current, It will produce maximum power at 2 ohms stereo, 4 ohms bridged mono. Running it at 1.5 ohms mono will shorten it's life.
Is why I had the ? mark there am not too familiar with PPI but if they give a stating that it is 1ohm stable and even a power rating I would hope they can back it with it running at 1.5ohm even
to get the most power out that amp with out hurting it is to
do a series parelell combanation, put both speakers in the
box wired parelell, then take a speaker lead about 12 inches
or so and run it from the negative from one speak to the
next. then run one positive from the amp to the one sub and
same with the negative. if you dont believe me just use a
multimeter to test the resistence, stick the multimeter leads
in the back of the box, each speaker will read 3 ohms
wire them in series it doubles too 6, bridge that bad boy at
6 ohms. my w6s always read 5 ohm per coil 11 in series but i
got 6 12 wired in series and the multi meter reads exactly two.
your amp is 1400 at 4 ohms 700 at 8 ohms so it will be over
a thousand watts. good luck.
Originally posted by eazye to get the most power out that amp with out hurting it is to
2....6ohm loads in parallel? 3ohms.....not 4....
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
771
The first two screws (IN+ IN-) go to the amp/radio. Second pair of screws (W+ W-) go to the woofer. Third pair of screws (T+ T-) go to the tweeter.
866
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
205
WasHere
WasHere
Indidnapolis, IN
WasHere
    Jun 1, 2024
    May 31, 2024
