headunit keeps overheating
  • 3
kado3000
I have a pioneer 9300R cd player,12disc changer and a crunch 4 channel amp power my mids and highs and a Mtx6500d amp powering two kicker 4ohm dvc compvr12 and a 1farad cap in a 1997 Rs Camareo.The problem is ,my headunit keeps over heating ,after being played for 20min or so .I tried bigger ground but it keeps overheating I don"t know what could be the problem.Can someone Please Help?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
While you are checking that out and if there is a problem or even a small problem with that being blocked you may want to look into getting a fan to cool the unit under the dash.
what ^ said. amp gain setting info, test tones are at the very bottom...
412
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
994
kado3000
kado3000
West Point,NY
Alaxan
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
