JL 1000/1 VS. Alpine PDX 1.1000
Also the JL makes rated power @ 11-14.5 volts, I think the PDX requires 14.4 to get the full 1000.
Yeah, but the alpines are underrated so even at a lower voltage you will still get the full 1000 listed watts.
1293 is awsome for that alpine, I wonder whats the rms on the JL 1000/1, anyoe knows?
Probably around what it's rated for. Remember that JL's RIPS system is a highly regulated power supply. Which is why it's rated to make the same power from 1.5-4ohms and from 11-14.5 volts.
I like the JL's bass eq, it helps a LOT with tuning in the lower bass, it controls the boost and not the overall gain.
My vote is stay w/ JL its a better amp.
Yup, the JL's run cooler then the PDX's
I think the PDX is a great amp, since it will fit anywhere, but if you got teh space go with a JL, since it will do rated at any voltage, and it has more settings then a PDX amp. So finer tunning
So IMO:
Overall:
JL>PDX>PG
Size:
PDX>JL=PG
Cooling
JL>PDX>PG
Sound Customization
JL>PG>PDX
Looks
PDX>JL=PG
Yeah a regulated power supply giving same output from 11 to 14.4 volts is something the alpine is missing.
Just keep the JL and mount it in the roof/headliner of the truck, problem solved.
Just got my new dual amp kits from kicker, its the 0/1 gauge hiperflex wire... will see if I mount the amps on the rear wall behind the rear seats.
I'd like to see something to back this up
Every birthsheet that I have seen for a PDX amp shows significantly more power than whats it rated.
My friends 1000 showed 1170 @14.4V on the birthsheet... So, yes you will get at LEAST the 1000 rated watts.
the PDX4.100 usualy rate from 120-130 @ 14.4.
They are underrated
They are underrated
my pdx birthsheet say 1293 lol
kmu
kmu
Tucson, Az...
kmu
    Jun 20, 2026
    Jun 20, 2026
