Two IA 40.1 Strapped TEST RESULTS!!!!
Korn4Life
SUB LOVE
Well I had a lil time at work today and I had the right meters (Thanks Maint dept) So anyways onto the test... Once I got my numbers I was very disappointed in the numbers I got but then I calculated for IMP RISE and made me feel a lil better.. I know I got to upgrade my electrical alot more to get the full potential out of my amps...
Amps are strapped @ 2ohms going to a pair of 12" DD 9512g's
I am running Stock 105 amp alt and a Stock Battery up front with 3 - Stinger SPV70 batteries in the rear
Starting voltage was 13.71 dropping to 10.91v during testing
129.1 V
31.34 A
4045 watts @ 4.1 ohms
So pretty much each amp is pushing 2022 watts @ 2ohms @ 10.91v
Not to bad
O and the test was done at 63HZ
now do a test at .5 ohms each
That is a question that im wondering... Since Im getting a 2+ohm IMP Rise would it be safe to run a .5ohm test? Each amp would be seeing .25ohms but after IMP RISE it should be up around the safe area.... ANy feedback would be great
You will be fine for a burp, but I wouldn't try to run them that low daily.
should be fine if you don't daily drive with it that low, because its going to pull more current and voltage is going to drop lower.
btw you don't have to capitalize imp rise //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well theoretically, you'd see 2668.81 watts @2 ohms @14.4 volts out of each amp
again, all theory, but just a bit all over the place.
just run one sub
strap it @1, run each amp @.5
Nice test buddy boyee! Get that voltage up and you may end up being as loud as me when im done with my next build.. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
You have to have a system in your car first to be loud.....LOL;) Im getting a ALT with adjustable voltage.... That should help out a lil.... I know I will be ok running at 15 volts just for a burp.... O and I didnt get that sub from by buddy but I did get something nice...
Im just fvcking with you bro. Just waiting on a couple things and then its game time... PM being sent by the way //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Korn4Life
SUB LOVE
Korn4Life
PA
Korn4Life
vegang
vegang
