Jeep won’t start when amp is hooked up
Never said there was.
Your continuing a stupid discussion....end thread.
Back to OP's topic.
You were telling OP that his problem is grounding to his seat bolts. You posted a picture of how to do it "right" that's no better if not worse. Hurry up and backpetal on that one.
OP's problem isn't related to his amp almost guaranteed, I explained this back on page 1. HU won't even power up while starting much less the amp. Whatever else he did when he "unplugged the amp and it started" is probably a clue but I don't think he is coming back.
Wtf? Your the one that requested a pic of my ground....now your twisting things a bit. I wasn't trying to show off //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
415
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
821
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
Dudebro241
Dudebro241
Pa
Boomin_tahoe
    May 18, 2024
    May 18, 2024
