OP
Dudebro241
- Thread Starter
- #16
I used a bolt under the seat and it seems fine. Amp runs nicely.Where did you grab your power wire?Is your battery terminal tight?
Seriously? Of all the things you have said in the past, I think this is the worst thing you have said. It's never a good idea to ground to seat bolt as carpet usually in the way. Metal to metal is so much better.What is better than seat or seatbelt bolts? Seems to me those are always set into places with the most steel.
Not always when there's carpet in the way.I never understood why people say not to ground to seatbelt bolt. That’s a big chunk of solid metal
Did you scrape the paint or just bolt it on?I used a bolt under the seat and it seems fine. Amp runs nicely.
I've never seen a seat or seat belt bolted into carpet, every one I've seen is bolted into a heavily reinforced piece of steel. Suit yourself though, if you can't figure out how to cut carpet, go under it, or find a spot without any ground wherever you like but you'll be hard pressed to find a more solid spot than where the seats and seat belts bolt in short of running back up under the hood.Seriously? Of all the things you have said in the past, I think this is the worst thing you have said. It's never a good idea to ground to seat bolt as carpet usually in the way. Metal to metal is so much better.
Seat belt bolts are solid in the chasis. Even in a sedan or hatchback the bolts for each in the back seats are never under carpet and are already solid and threaded. I don't know how you'd do better elsewhere.Oh I can find ways...I wasn't born yesterday. However, my seats are on carpet, bolted to the chassis. A lot of vehicles are like this. Also a lot of newbies do this too.
My suggestion still stands and cannot be argued with: ground to a sanded solid chassis is so much better than a seat belt bolt.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Actual chassis frame bud. The ground in my s10 is in the ext cab area, under carpet. Gotta be careful tho as it's close to the fuel tank.Seat belt bolts are solid in the chasis. Even in a sedan or hatchback the bolts for each in the back seats are never under carpet and are already solid and threaded. I don't know how you'd do better elsewhere.
OK, so run the ground out, drill a hole through the frame then use nut and bolt or do you tap some threads into it and bolt into that? Got any pictures of this?[/b]
Yep, here ya go...OK, so run the ground out, drill a hole through the frame then use nut and bolt or do you tap some threads into it and bolt into that? Got any pictures of this?
Yes ... then there's always the shade tree special... self tappers...Yep, here ya go...
This is what the original ground was when I removed everything. Pretty pathetic huh?! scraped a few times from a flathead screwdriver then throw on a spiked washer/screw call it good.![]()
That's into the frame? How is the steel there thicker than where seat belts and seat bolts attach?Yep, here ya go...
Never said there was.That's into the frame? How is the steel there thicker than where seat belts and seat bolts attach?
