Is this a worthy set-up?
the $189 id ctx65cs is two mids, two tweeters, two crossovers. all u need.
all it would take is grab a 4 channel amp, and a simple 12, like ssa dcon for $125.
maybe look for a cheaper 4 channel amp rather than sundown
so then i'd need 2 sets total for my car?
i originally thought the $189 was for all four speakers
It's just so expensive //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The set-up I posted is ~$1,100 and that's without install kit and install cause I won't be installing it myself.
And, what if I don't have tweeters currently? Do I NEED to use them?
That should be about $800 before install.
Alpine CDA-9887 CD, MP3, WMA Receiver with Remote New! - eBay (item 140514133307 end time Feb-25-11 15:49:51 PST) $329.00
SAX-125.2 SUNDOWN AUDIO 2 CH NEW 800W MAX SUB AMPLIFIER - eBay (item 110571829334 end time Mar-08-11 13:38:01 PST) $249.99
WoofersEtc.com - CTX65CS - Image Dynamics 6.5" Component Speaker System $189.99
that's my question, is the $190 for just TWO speakers? i was under the impression that i would need to buy 2 sets, one set for the front and one for the back making it $380 total.
In the car audio world, for the most part we only put "mid/high range" in the front. Some people say, "It's like a concert"-- don't listen to them. #1: It's a lot less expensive if you just put it in the front, #2 You WON'T hear a difference.
The whole concept of it is that you, the driver, will hear it very clearly and loud. If you have passengers in the back, they will be overwhelmed by the bass. Since you aren't running a sub (which is a mistake, since component speakers are not meant to have a lot of low end, just enough to support the bandpass between the 60-150-ish Hz range.), you will be lacking a lot.
Get a nice cheap sub, and you'll be golden with:
-The SET (That is, the 2 mid, 2 tweeters, 2 crossovers) of Components,
-A 2-Channel Amp... it doesn't have to be Sundown, or Kicker... any amp will do. Just go on the classified section and look for a 2 channel amp in the 100W RMS @ 4-ohm range
-Headunit.
If you have those three things, you will be fine. Now, I'll warn you now: It WILL leave something to be wanted. The components will not give you a full rich range, and it will sound kind of "hollow". But a nice cheap 8" Sub with a matching amp, and either buy a prefab box or have someone make you a nice small ported box tuned low, so you'll have a nice roll off.
Then you'll have yourself a nice little system.
PS: This is NOT a cheap game. Car Audio is expensive. You have to throw down a grand just for a novice set up.
EDIT:: As for your actual CHOICE of equipment: It's wonderful! Truly great. ID make great drivers, Sundown has the same layout as the big names, and are somewhat less expensive, and the owner's a cool guy, and the 9887 is one of the best HU on the market. (At least last time I checked).
oneal34
oneal34
Austin
oneal34
