is this a good setup ??
It will work for one of your subs.... not both. The amp is rated 380x1 at 4 ohms(your sub has a single 4 ohm voice coil and can be hooked up at 4 ohms). You could not hook both subs up at 4 ohms and if you could you would still be underpowering the subs quite a bit.
As I mentioned earlier look at a bd1000, a kx600, 1000d mtx, 1501d. If ya look hard you can find most of these used for under $200.
yes it will u just got to make sure you wire them correctly
The amp is rated 380x1 @4ohm
and like 200x2 @2 ohm. If the sub is a single 4 ohm. He can't do that.
I know quite a few folks on here run pioneer.
Do These Subs Come In Single 2 or Dual 4?
well umm... My price range for an amp is about 100-250 idk the coil config of my subs but i know they are Pioneer TS-W306C and i want enough power to thump
If these are them...
http://miata.cardomain.com/item/PIOTSW306C
Id get one of these amps...
http://www.thezeb.com/p-Visonik-Compact-Class-D-VXD709-109075.htm
http://www.thezeb.com/p-Power-Acoustik-Gothic-OV2-1600-103323.htm
http://www.thezeb.com/p-Power-Acoustik-Power-PS2-1600-108783.htm
http://www.thezeb.com/p-SPL-Series-V-ST2-1920-110783.htm
Honestly you have 2 wire options.
1 channel amp at 2ohm
Or a 2 channel amp at 4 ohm
Look for an amp that puts out close to 800x1@2ohm, or 400x2@4ohm.
dhsreppin
dhsreppin
Miami,Fl
Johnny Drama
