behringer ep1500
if it can be run and 8 and 4, 7 won't be a problem. w7 3 ohm coil....no amps rate at 3 ohms but the w7 gets along just fine.
thanks......i just bought a 3.5 dvc sub. how much power would you think it would recieve?
You need some sort of a crossover for these things - because they don't have one built in.
And unless you have a balanced source, you can't use the XLR balanced inputs to their full advantage. Stick with RCA to 1/4" TRS adapters instead.
And you'll need 1/4" TRS to banana plug adapters, but PE as well as most pro audio shops stock those as well.
dude, those dayton sub cables are the best value ever. anyone who tells you that monster cable or anyone else is better, shoot them. i have the 15 foot and it is cleaner than my monsterbass one.
and its cheap. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Parts Express sells adapters that are RCA on one side, 1/4" on the other...it plugs into a TRS jack and gives you an RCA jack instead. Then, you simply run your RCA cables like normal. For the speaker wires, something like the first link you posted is what you need.
swc204
swc204
pierre, SD
swc204
michigan born
    May 14, 2026
michigan born
    May 14, 2026
