Is there a sub that can handle 6000-7500 watts daily?
Ok say 3500-4000 daily and 6000-7000 watt demos (30 mins max)
you can spend all the money in the world and still not find a woofer to take that even for 30min. shot I've burped once with 8k and you could feel the heat on the dustcap.head over to youtube and look up dbdrag deathmatch.they are using about the same power you are wanting if not more and there subs wont last 3min
30 minutes straight at 6-7K? That's still a ton of power to one sub for a long *** time. The most I've seen one sub take in person (on music) came out of a TC/AP LMS wired to a Cactus 7K but wasn't taking nowhere near all of that amp. And certainly not for a half hour.. Your out of your mind..
first off alot of subs can take it because your not going to truely feed it 6000-7500 continuosly. Your not going to play the exact same note constantly let alone keep up with the voltage and amp draw. As the speakers move back and forth it changes the load to the amp so it isnt going to be the same either.
So any top end sub will do. DD, T3, FI, etc.
Oh and if you were able to feed it a true 6000-7500 continuosly, you will blow apart any and every sub. Very few can take that real power without creating major internal heat and unwinding the coils. Coils can only handle so much before you burn them or the glue gives and unwrap in the gap. DDz subs I have seen hold up but still end up going in the end
mgcauctions09
mgcauctions09
alabama
Boomintempo
