Is there a rca distribution block to run multiple amps
maxxlink is a bridging module isn't it? That doesn't have anything to do with your question.
You can either use the rca outputs from the amp - if it has them, or just use y cables.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
867
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
897
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
849
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
942
corollabass
Aurora,CO
n2audio
