y bother, hell come back with a excuseCheck this shit out. You made this plan in the pic. Well, to put it simply, no you didnt. You messed it up, you didnt build it right. Its very obvious by the video. You have a 13.5" sub, correct? Well, the box plan only calls for a 14" height of the box. You have way more room than 14" judging by the size of the 13.5" sub. Your box is too **** big, its not built to that design at all.
Im sure he will. Bottom line, that box is not built to spec. If he cant get that through his head he SHOULD give up on subs. Cuz honestly, if you can use a box calulator online, its NOT hard at all to figure out the d*man box size/volume. Better yet, hes asking what to cut the box to, when its RIGHT THERE. All he has to do it look at the box plan, measure and mark the box TWICE before cutting, and there you go. Box built to correct size.y bother, hell come back with a excuse
Ya but that would be too hard and too much work. He needs us to tell him EXACTLY how to cut the box, even tho the measurements are right in the thread...probably be easiest to cut the right side off to whatever length would give the correct cuft and then simply glue on a new piece
Maybe if you hadn't built the box 3.5 GODDAM INCHES TOO TALL you wouldn't be in this pickle.Width 32 inch
Height - 17.5
Depth - 16.5
Thickness - .75
