Installed and ran into some problems
outspoken does not understand that the terminals on a monoblock are paralleled in the amp...you can do it either way, but it will work exactly the same
Alright, so the speakers were already hooked up correctly, I still dont know the problem though..
hmmm... i would think it would have to be left + and right - if i am wrong my bad... thats how i always wired them...
look up a link for monoblock amps and check the schematics....inside a monoblock, there is only one channel...hence MONO
there is no left and right...they just label it that way
ohhhhh //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif you are right sir, my bad... this amp has a left + and - and a right + and -, i thought you would have to wire it like a 2 channel in that case... disreguard my idiocy...
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=PBI&MfrPartNumber=648349&CategoryCode=3389B
this is the one i use, and it works fine...if you get one, you can test the resistance at the amp to see if it is correct, and then you can set the gain correctly....you may have an issue with the gain on the loc, which you also can set with this dmm
So you think this is the problem? I don't want to waste my time with everything I am pretty frusterated with this so far, and I dont know how to use a DMM anyway as it is...
Asian Invasian
Asian Invasian
FTC
Asian Invasian
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
