Installed and ran into some problems
Ya I know, Nothing is going my way because I lost my thing that hooks my camera up to my computer.
I am just going to best buy and paying them to fix it, **** this.
its out in my car which is in a garage kinda far away right now, i have no idea, i bought it from best buy.
The problem is the sound of the bass, it sounds so dull and crappy and when i go partially loud enough it sounds very choppy in the bass.
you have to wire the subs at the correct load for the amp...this is why i asked earlier
edit: #4 from the original post
I am no good at this stuff, can you tell me how I am supposed to wire the subs are the correct load..
here is my setup:
Subs:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300196566642
Amp:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2961
On my amp is said left and right and have positive and negative. I hooked the left sub up to the left with + and -. and the right sub up the where it said right (on my amp) + and -.
wire each sub to + and - to get 2ohm load, and then set the gains w/ dmm...this amp puts out less than half what you need
edit: each sub to its own + and -...that amp is a monoblock so it will effectively parallel the subs 4ohm and 4ohm to make 2ohm
The subs only use 150W each...
There are two things for speakers on my amp, one says right and has + and -. and one says left and has + and -. I hooked one speaker to left and one to right...
I must be doing something wrong..
Asian Invasian
Asian Invasian
FTC
Asian Invasian
