inline fuse for Orion XTR 1500.1
  • 4
300 is way too big, if you ran a 300 amp fuse on that amp you might as well run straight wire. 150 amps is big enough.
y most 0ga amp kits come with 250-300a.. i've always said to go smaller like u say 150-200 but they come with bigger usually
looks like like i'll put a 300 amp ANL fuse.
i'm going to be building this steup to run two Sundown SA-12's in a ported box . just joined the forums here yesterday , thanks for the replies , much appreciated ....
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
584
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
02Blazer
02Blazer
San Diego, Ca
02Blazer
slater
    May 2, 2024
slater
    May 2, 2024
