In-line fuse size
Big D 13
My car was wired for a 750W amp, and it has a 80A in-line fuse. Now I want to use a powered sub with built in amp (nominal 350W) that calls for a 20A fuse. Should I swap out the old 80A fuse for a 20A fuse? Or add a 20A fuse somewhere along the line? Any guidance will be much appreciated.
The fuse is for the wire, so 80's still ok (assuming it's at least 4-5 Awg), although changing it out for a 20-30A fuse would be providing better protection.
I'd also recommend swapping it out just to keep things consistent. I wouldn't toss the 80A fuse, though, just in case you decide to upgrade again later, not to mention having a spare on hand.
Thanks
Thanks
Big D 13
Big D 13
Big D 13
