IDK wats wrong.
  • 5
Tone415
A.K.A FrisnoG
I have a JBL gtq200 hooked up to my 6x9's and 6x5's. 1 speaker on each channel. i have a dist. block from my main batt and comming out the other side is a 4g for my sub amp and a 8g for my JBL amp. the ground is good for both amps and they both turn on. I just installed brand new rca cables from the dash to the amp and from one amp to the other.my subs still work perfect, but all i hear through my 6x9's and 6.5's is bass!bought new speaker wires n installed them but still only bass. tried my power acoustik amp and the same problem. tried another 1way 6.5 still same problem with both amps.. now is the problem in my amp or speakers or wires or whaT? i tried everything to fix it. any help?
i ran rcas direct to amp still didnt work.. the settings were all high pass on or both were on. gain set to half on each.. head unit is a jvc KDR200..
Have you reset all of your head unit setting back to factory default? That would be something I would try. Or you could try and hook up an iPod directly to the amps and see if you get the same results.
You could always go back to a regular RCA into something like this https://showtimeelectronics.com/collections/sbc-cockbox And then use whatever...
915
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
59
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Yeah, I plan to run them in my workshop. I haven't gone through them or anything but they startup and run just fine. I don't see any strange spike...
Tone415
A.K.A FrisnoG
Tone415
San Francisco, CA
loopkiller
    May 18, 2024
    May 16, 2024
