Update as promised!
The box in the truck, very very tight fit!!
As you can see, part of the box will be vissible, I think I'll paint that part of it black, just so it doesn't stick out.
Another little "fix" I had to make so the box would fit. I'm waiting on the pieces to dry so I can put them on the box...
What it will look like with the seat back and out of the way...
From the passenger side...
Pieces I'll use to box out the nob for the seat..
The other nob piece...
Looking through the passengers window...
Its really coming together now. I had to add a spacer to the sub recess b/c of a stupid miscalculation I made. I put the sub up to high on the front baffle so the mag was hitting the back wall. I made another ring and cut it in half to life the sub up a little more. Easy fix but now the sub surround is about 1/4" past the baffle. I plan on putting another ring around the sub recess to try and keep the sub from hitting the seat. I'll just have to make sure I don't play it to loud when I have the seat back. I'm actually debating doing another baffle so the sub will be a little bit more protected. Idk we'll have to wait and see. I really don't want to b/c making a new baffle takes a lot of wood.
I might do a little more work tonight, depends on if I go out or not. Other then taking it apart and glue and caulking everything this build is pretty much done!!
Jon
