I need an amp that is guaranteed to put out at least 1100 rms
Sundown amp's great and all but even they can't make a Audiobahn sub sound good.
this , OP wont be happy with any amp those subs wont sound good i have had a few sets only one pair had decent sound and that was the 400 rms subs i out in my dad's car , that wasn't made to get loud but fill in the missing bass.
So do to my shitty stock alt would buying that Hifonics amp I posted a couple pages earlier do me right? Wiring at 1 ohm?
I'd still get the 1500d. If you set the gain to where you're only getting about 500 watts to each sub it wouldn't be any harder on your alt than a 1000 watt amp. When you decide to upgrade you can add a good battery in the back and you should be fine. If you're too afraid of the 1500d now db-r has the SAZ-1000D listed on his website for $247.50 for a refurbished one but I don't know if he actually has one available. I'd choose that over the Hifonics.
So far, thanks for everyones help in trying to get me straightened out. I now know that my amp is ****, my alt is ****, and my subs are ****-ish. Sooooo, not to //content.invisioncic.com/y282845/emoticons/beatdeadhorse5.gif.5d70132dea1eb89b73bf2fdbb6027dd6.gif would it be more cost effective to get 2 12's that the amp could push? dB-r, u figured that the amp is only pushing about 400 watts correct? Im assuming thats would considered RMS. So, should I try and look for two 12's that are 350 to 400 rms capable?
I don't think you'd be satisfied with it. If you want to go with ~1000 watts 2Alpine Type R's would work well in a nice ported box with proper airspace and tuning.
Well, i've mostly given up, just trying to get something from the amp you know. I will eventually find a H/O that will fit my yaris and not cost $500 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Do you think that I could push two Kicker CVRs? With about 400 per channel?
If db-r calculated right you're only getting 400-600 TOTAL from the amp. Put it on Craigslist and you can probably get most of your money back out of it.
I would get this:
Sundown Audio SAZ-1000D + 2 x Sundown Audio SA-12's.
Will work with your Yaris electrical and sound great.
660
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
964
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
slick327
slick327
Houston Texas
dB-r
    May 18, 2024
    May 16, 2024
