I have to run 6 300 amp fuses?
mgcauctions09
Is this correct. 2 runs of 1/0 from front battery then both get fuses then go to my back batteries and both get fused again right before connecting to the batteries then they come off the rear batteries and both get fused again?
That is a total of 6 300 amp fuses. Is that about right? Does that many fuses take away from voltage/current flow?
connect the amps, to the run of cable from the front, to the back of the car...
so effectively, you have two 600amp fuses on that cable, while the run from the front, to the back, is still also fused..
mgcauctions09
mgcauctions09
alabama
mgcauctions09
