How to run amp from OEM Navi/ OEM Amp?
subydude81
NY
OK my cars a 2006 acura tsx with built in Navi and I have stock comps in front, 6.5s in rear doors then 6x9 subs in rear deck. I'm keeping the factory Navi so how would I go about running an amp to the front comps and rear 6x9s.
I have a 5 channel Hifonics amp but not speaker level inputs. I know of LOCs but since the wiring from the Navi goes into the factory amp i'm not sure how I would get enough signal for 4 speakers.
I'd like to just bypass the factory amp and run the 5 channel to all speakers, I know rear door speakers don't need the amp but might as well since I upgraded those rear door speakers.
Find the wires sending signal from your HU to factory amp. Cut them off, and wire in a LOC. No more signal sending to factory amp, new RCA outputs for your new amp.
2006 Acura TSX Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red
Car Stereo Antenna Trigger: Yellow/Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the center of the dash near the front of the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/Blue
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Pink
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Violet
if i recall correctly that headunit has low level ie rca outputs to the factory amp. I would get a peripheral sven4 and use that to tap in and get ur signal before the amp
subydude81
subydude81
NY
pentavolvo
