I have a problem with subs not hitting lows.
CSA
My subs don't hit lows and its because of the amp I have, is there any way to fix it without getting new amps?
(I found out it was my amps by borrowing a different amp and using that on my subs and then they hit lows just fine)
The amps that I am using is a old school hifonics centurion X's which I have two of. (I had three at one point but they all had this problem)
Thanks for your help
If you can't adjust the hpf(ssf) below 30hz or the amp rolls off you can possibly spend money getting the preamp modified but it might be cheaper to simply get a new amp
How would I modify the preamp? Its all through hole components. Hpf only goes down to 60hz on the dial if I remember correctly. Lpf goes downtown o 30hz
Here is a pictures of the internals of the amp
Boost is MaxLevel is around 50%
Hu is jvc kd-r310
Yeah the dial is around 11oclock 80hz lpf
bass boost should never be used ever.
your gains is high as well.
You need to go up to 80% of the head unit's max volume
subwoofer level maxed out on the head unit
bass boost and loudness off on the head unit Bass EQ flat zero
bass boost off on the amp. then reset your gains again.
i'm surprised you havent blown anything with those amp settings.
CSA
CSA
Carlson City
CSA
Mike Mccabe
