I can't get my mdf rings to stay in place on my kickpanel project???
loudfivepoint0
When I try to hot glue the mdf rings to my kick panel (plastic material) the supports won't stick to the plastic material. I have thought of just making myself a fiberglass mold but there is part of the kickpanel I couldn't recreate from fiberglass because it is very thin and extends up to the window. At least I don't want to recreate it.....Could i glass the lower part of the kickpanel, and then hot glue the stuff on? Would the glass stick to the plastic? I'm getting very aggrivated at this stuff. BTW I'll be using cdt ef-61 comps and they are supposed to have really good off axis sound. So is it THAT important that I angle them directly at my ears? Or should I maybe try to keep them from being pointed directly at my ears......and for all you imaging freaks out there, there is only a 6" difference between my kick's distances from ear to speaker. Sounds pretty good. Any tips for me.....I've only done one fiberglass install. And I trashed it too.
I don't know if this will work for what you are trying to do, but how about using rivits? You could countersink the rivits into the MDF also so they would not interfere with the speakers. Just a thought!
dont forget, epoxy resin is NOT MEANT to bond well to ABS plastics.
youd be better off trying to fabricate the entire piece //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
996
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
  • Locked
Definitely not rubber, it looks like ABS. I like this grille but it does not include a trim ring. It is designed to tuck under the OEM rubber gasket.
loudfivepoint0
loudfivepoint0
Hot Springs, AR
Insomniac119
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
