Hows this set up sound?
mTx005
Hey guys i waz just wonderin how u think this set up would be in a 95 camaro...I got 2 MTX 8000 12"s powered by an Legacy 1600 watt amp...the amp was w/the left over cash so i just got a cheaper 1 still 200 dollars tho..n i got a Pioneer DEH9400 cd player...that sound like a good set up?
thanks
yea but theres no telling how long it will last tho ... i might be wrong but ive heard alot of bad thigns about legacy an i havent had any good luck with them either...
How many watts can the Thunder 8000's take continuously? If it is 400 like im thinkin they are then you might want to look at a Profile CA1200 or CL1200. JBL 600.1, or some other good amp like these if you are on a budget. The Profiles I mentioned both put out their rated power and put out exactly 300x2 watts rms at 4 ohms. They put out 410 watts rms at 2ohms per channel. When they are bridged at 4 ohms they put out 900 watts rms. The JBL put out 300x1 rms @4ohms and 600 watts rms @2ohms. They are also underrated so your lookin more toward about 375 @4ohms and about 750 or so @2 ohms. It is also a class D amp so it will put less of a strain on your electrical system then the Profiles which are Class AB.
mTx005
mTx005
washington, wv
85ss
