how would this setup do?
94yodapickup
jax fl.
ok i have an standard cab truck an i have some bucket seats so i have about an 10 inch gap between my seats an i plan on placing an xxx 15 were its firing in the box. u no were the magnet is all u can see. But any ways im doing this because i dont have much room behind my seats an i plan on using an 2 cubic ft box sealed with either the re 35 amp or an jbl 1200.1 an i was wonderin how this setup would sound im about 60spl/40sq
i wouldn't run the 15". if it were my truck i would run two 10"s in an isobaric enclosure because of lack of space. anyway, that is just an opinion, it is your truck, do what you wish.
my buddy did it with an audiobahn 12 high excursion it sounds realy good. he actualy mounted his amp to his headliner! its a very clean install. port your box, and dont forget to reverse polarity on the subwoofer when inverting! i would go for it. btw his is an 94 s10 and he took out the middle arm rest and the magnet sticks way out. its tits!
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
801
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
94yodapickup
94yodapickup
jax fl.
lephatrabbit454
Decebal
    Jun 10, 2024
