//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifEhhh...no.
Helotaxi was on point...saying distortion causes blown subs is to misunderstand what's actually happening here.but again the clipping itself still has nothing at all to do with the blowing of the sub, exceeding the subs thermal capability does.
Only problem with that explanation is that the author assumes that an amp driven to clipping still sees an average power increase. Truth is that an amp clips because its average power output is at the maximum sustainable by the power supply. The amp then chops the tops off of the signal in order to apply that power to the lower portions of the waveform. So it turns out hes wrong.http://www.audiogroupforum.com/csforum//showthread.php?t=4332
Specifically read this reply. I don't think I've ever read/heard a better explaination of "underpowering a subwoofer."
Tempe
An amp clips when its MAX voltage attempts to exceed the voltage of the power supply rails. Has nothing to do with average. Clipping will allow an amp to increase its average power output beyond its design capability, it just won't be linear, low distortion output any longer.Only problem with that explanation is that the author assumes that an amp driven to clipping still sees an average power increase. Truth is that an amp clips because its average power output is at the maximum sustainable by the power supply. The amp then chops the tops off of the signal in order to apply that power to the lower portions of the waveform. So it turns out hes wrong.
