How to turn on aux2 with 880prs?
Pickler
Las Vegas
I hate seeing questions like this because they are so simple but I have been searching EVERYWHERE and can't seem to find out how to turn aux on with the 880prs. I installed a pioneer pac ipod unit and when I go through the sources it doesn't seem to recognize the the source and I am unsure how to go about turning in the aux source.
(also my battery is dead in my remote so hopefully I don't need that to turn it on.)
help //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
turn off the unit, hold down the function button (I think it's function or maybe audio), and it'll pop up more settings. You can turn off the internal amp and it has an option for you to either turn aux 1 and aux 2 on or off.
U have to pull the cd player out of dash and theN take it apart( only a few screws) and inside u will find a aux switch which uhave to turn on.
no...
thats to switch it between standard and network.
the aux is under the menu, but the hu has to be off.
turn off the hu, push the right knob in and hold it for a couple seconds and it will bring you into a menu where you ca adjust the time, aux's, brightness, att setting, etc...
no...
No..... We are both wrong.
U have to take the engine out. At the very bottom, after it's all torn down there should be a aux button that u have to switch to on.
Fyi my first post was a joke, this is the correct way.
Thank me later
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
871
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
Pickler
Pickler
Las Vegas
Blue Fury
