How to select the proper fuse size
lotas
There seems to be a lot of questions regarding fuses and fuse sizes lately.
Here are some helpful hints in the process to find the right fuse for you.
1.) Determine your wire size's max. amp capacity. Refer to http://www.the12volt.com/info/recwirsz.asp to find your wire. A lot of people run 1/0 so we will use this as an example. The max capacity is 350amps. This means that if more than 350amps are running through the wire it will burn. The point of a fuse is to have the fuse open before this wire burns.
2.) Next, you have to understand the point of the fuse as explained earlier, so obviously you want to make sure the fuse is not larger than the max. capacity of the wire, as we want the fuse to open (or blow/break are other terms) before the wire burns. So right now we are looking at fuses under 350amps.
*By the way... When you are dealing with a fuse size up around 300amps or so, you will probably be looking at ANL fuses (the long ones horizontally, with a sort of spade terminal on each end), not AGU (the cylinder ones) or MAXI (the colored plastic ones found in you car/truck fuse box). *
3.) Next we have to make sure that your equipment will not draw too many amps to open the fuse. **IF YOU DO NOT HAVE A HIGH WATTAGE SYSTEM YOU CAN SKIP OVER STEP 3** For this step, we have some calculations to do. Let's say for arguements sake we are running a 1500watt Class D mono amp for our subwoofer, and a 300watt Class A/B amp for our components. To calculate the estimated amps that each of these will require, here is a quick calculation.
A.) Take each amp, one at a time, and take the amps RMS and (too be safe) divide by 12. (More realistically, your car runs at about 13.8volts, but to be safe, use 12. You could calculate for 12volts and 13.8 and average the two, but we are just looking for a ballpark figure).
1500(watts rms)/12(volts) = 125amperes (or amps) current
300(watts rms)/12(volts) = 25 amperes (or amps) current
B.) Next you want to account for class efficiency. Class D amps are about 80% efficient, so take your figure from your class D amp, 125amps, and multiply it by .2 (or 20%) to add efficiency.
125amps * .2 (class D efficiency) = 25amps
Now add this figure to the original
125amps(from the total RMS/12 of the class D amp) + 25amps (the class D efficiency) which gives you 150amps. So your 1500watt class D amp will draw around 150amps. Already you can see what could go wrong if you used a 150amp fuse, for just this amp alone is drawing around 150amps, which could open our fuse.
Now for the 300watt A/B amp. A/B amps are about 60% efficient, so multiply the original figure by .4 (40%)
25amps * .4 (class A/B efficiency) = 10amps
As we did with the Class D, add 25amps (total RMS/12 from the A/B amp) and add the 10amp (Class A/B efficiency) = 35amps
C. This gives you 150amps for you Class D amp, and 35amps for your A/B amp. Therefore your system will pull around 185amps, at full RMS, at 12volts (although when your alternator is running, you are at more around 13.8volts, which would give us a smaller figure than 185, more around 150 or so)
4.) So as we know our fuse must be rated ABOVE what our system will draw, we now know approximately what our system WILL draw, which is 185amps. Therefore our fuse must be under 350amps, and over 185amps. A 200amp or 250amp fuse would be fine for this situation, most people go with a 250amp fuse on 1/0gauge.
I am no electrical engineer, so please, feel free to chime in on anything you feel is wrong and should be corrected, or any questions. I will gladly edit and make changes. Thanks for your time, I hope this can help a few people out.
Just a quick note.
You should use the Peak Wattage values of your Amplifiers, Not the RMS values.
Peak is always higher than RMS, so when your Amps reach their Peak Output, they will blow a fuse rated to handle the RMS value
Just a quick note.
you = idiot
that is all
A usfull tidbit for those who don't know, a fuse or breaker can actually handle much more than its rated amperature in short bursts so using peak wattage ratings is not going to give you ideal protection, you need to establish the nominal current your amp will consume then choose a fuse/breaker that will allow for it.
For example-
In one of my systems I had 2 amps, the sub amp had four 30amp fuses on it and the four channel had four 25amp fuses on it. Thats a total of 220 amps of fuses yet I only had a 100 amp breaker under the hood that only tripped once in over a year.
Why?- the amps had a nominal usage under 100amps, they would draw peak amperage over 100amps in very short bursts the didn't linger long enough to trip the breaker. The one time the breaker did trip was a very hot day and I was really pushing the systems limits, a very hot amp will start drawing more current until it finally goes into protection, blows its onboard fuses or blows your underhood fuse/breaker, the underhood breaker tripped before the amps reached their critical point.
But lets not forget the first and formost reason for having an underhood fuse, if your main power wire shorts out on the chassis of your car it can start a fire and burn your car down to the ground.
you = idiotthat is all
Please explain how my post makes me an idiot.
**An amplifier with an RMS output of 120 watts has a Peak output of ~180 watts.** There is no way around this.
Using the formulas given above:
120 Watts / 12 volts = 10 Amps
180 Watts / 12 volts = 15 Amps
All of a sudden, Our system has the ability to draw up to 50% more power than we originally accounted for.
Now using the Amplifiers described above:
1500 Watts RMS = ~2250 Watts Peak
2250 Watts / 12 Volts = 187.5 Amps
187.5 Amps @ 80% efficiency = 234.375 Amps Total
300 Watts RMS = ~450 Watts Peak
450 Watts / 12 Volts = 37.5 Amps
37.5 Amps @ 60% efficiency = 62.5 Amps Total
234.375 Amps + 62.5 Amps = 296.875 Amps MAX Current Draw
POP goes the 250 Amp Fuse.
Granted I will admit that this only applies if you run your System at it's maximum possible output for long periods of time - Something which I hope none of us do. I will also admit that the fuses are there to protect the WIRE, not the Amplifiers.
** I used 120 and 180 here because these are numbers that I know to be within 2% accuracy**
That 296 is an instantanious peak, the 250 amp fuse will handle the short bursts without blowing, the fuse/breaker needs to heat up before it fails, the rate it heats up is in accordance to how many amps are flowing through it.
For example-
Say the flesh on your fingertip is rated to handle 70 celcius (canadian) but you can quickly touch a hot surface over 70C without getting burned, as the temperature gets hotter the amount of time it takes your skin to burn shortens.
Like a hot potato to a burning peice of coal, you can touch the hot potato for a short time and possibly if your quick enough tap the burning coal without getting burnt all the while your skin is rated for a much lower constant temperature.
See what I mean?.
That 296 is an instantanious peak, the 250 amp fuse will handle the short bursts without blowing, the fuse/breaker needs to heat up before it fails, the rate it heats up is in accordance to how many amps are flowing through it.For example-
See what I mean?.
that is correct
I believe the fact is that a fuse can handle 200% of its rating for 5seconds. So I wouldnt worry about the max rating.
bump for more help
But if you never run your amps past the point at which it starts to distort, than you'll have no problem (with the exception of SPL competitors). If the fuse blows because the current that the amps peak at is flowing threw it than the fuse did it's job. Sure most amps have internal fuses, and the main job the the inline fuse is to protect the wire, I'd still want the extra protection.
Lets look at your example. Your math shows that the MAX current draw is ~300amps, yet the wire's current flow can't excede 350amps. The problem occures when only 300amp and 350amp ANL fuses are avalable. 300 would "pop" and yet 350 would be not enough protection from fire (not enough for my comfort). The obvious solution would be a bigger wire, but all is beside the point.
Most people are going to benifit best from relying on RMS calculation and not peak. Like said earlier, only SPL competitors are going to drive their amps to such limits and then they can get the 2/0, 3/0 wire. But for the average intaller there is no need to run peak current.
Sorry to resirrect an old thread, and no disrespect, I just wanted to clearify something and bump a very helpful thread back to the top //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
391
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
585
lotas
lotas
Washington
Eviljacket
SlugButter
    May 4, 2024
slater
    May 2, 2024
