how to paint or fiberglass sub box
thanks for help and info just want a simple black coat nothing fancy
---------- Post added at 07:18 PM ---------- Previous post was at 07:18 PM ----------
what u mean round all edges u sayin glass the box with 3 coats of fiberglass
Round over bit or orbital sander. And yes glass the outside
If you aren't making some sort of curved shape there is no need to fiberglass anything.
Spray a few coats of automotive primer on the box and then sand it with 180 or 220 grit paper. Then spray another two or three coats on and sand that with 400. It's best to sand with a block but if you don't have one, sand in a circular pattern to avoid cutting grooves with your fingers. The grooves may not be noticeable in the primer but they will in a glossed finish. Oh and, a short piece of wood makes a suitable block.
Once you have the primer sanded smooth with 400, paint with basecoat clearcoat or with a good enamel from a buzzbomb. And if you happen to sand through the primer ANYWHERE, spot prime it lightly before painting because the raw wood will soak up the paint and make the finish dull.
ok cool yeah i dont need nothing fancey i was just want something simple and nice
biglion
biglion
nahsvlle tn
biglion
