rca help
f0x40und
I'm hooking up a new audio system I got 2 alpine type s 12 inch 4 ohms hooking up to a power acoustik ps4-1200 I'm trying to wire my subs up by bridging channels 1/2 and 3/4 and I just bought the rca y splitters and here is where I get confused the rca inputs are not color coded I'll upload a picture to show what I mean but channel 1,2,3,4 are just black so how do I hook up my rca cables and after that my amp had a channel switch on it for 2 3 4 witch one should I have it set on the pictures I upload are of the rca splitters I'm working with and the rca inputs on my amp that are just all black thanks for anyone who can help
images.aspx
sorry that's my amp i uploaded the wrong one before
That amp will not be nearly enough to power those Alpines man. You need a mono block that runs 800-1000rms to power them correctly and that will not even come close. But, to answer your question, it doesn't matter how you hook the Y connectors up. Just plug in all 4 channels and bridge it. Switch it to 2 channel. You're running subs so it doesn't matter. Make sure each sub is wired in series though cause that amp can't handle 2 ohms bridged.
f0x40und
f0x40und
United States
f0x40und
