How to have a well rounded setup with 8 speakers?
Newah
My 2003 VW Golf has 4 6.5" Door Speakers, and 4 tweeters, 2 in back, and 2 in front.
Could I get away with mid-bass range speakers in my doors since I have the tweeters? Or at least the back ones?
This way maybe I could get by without a Sub (savin money) - NOT that im EXPECTING it to sound like a have a sub, just bass that isnt distant.
Its all powered by a stock multichannel amp in the back (Monsoon)
If you want bass, you need a sub...
Although there ARE 6.5" subwoofers out there; you could put two of them in the back. You'll want some kind of crossover (or an aftermarket amp) otherwise you'll be playing higher frequencies through the sub and it'll sound like crap.
I don't need it'll sound like subs. I've never had subs in any car before and I've lived, so that's where my idea of saving money, and (for now) change out the rear speakers for Midbass ones, and install an eq for AUX input
This sounds like a pretty standard setup. two front comps + two rear comps. I'd suggest to look into getting a compact class D 5-channel amplifier. Then you can amp all speakers and potentially a subwoofer without losing much space. And should you move into higher end setups involving active 2-way front stage, then you will have enough channels to power active front + subwoofer. Alternatively, you could start with a 4-channel amplifier powering all speakers, but when the time comes to add a subwoofer, disconnect the rear speakers, bridge the two channels for a subwoofer.
Mid bass needs to be in front of you. It starts getting in to the not omni directional freq range.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
573
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
973
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
895
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
Newah
Newah
Michigan
LosIsATool
    May 16, 2024
    May 16, 2024
